ArcGIS.Core.Data.Realtime Namespace / RealtimeFeatureClass Class / SetExpirationMaxAge Method
The System.TimeSpan indicating features older than this value will be removed.
    SetExpirationMaxAge Method (RealtimeFeatureClass)
    Sets the expiration maximum age for features. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetExpirationMaxAge( _
       ByVal expirationMaxAge As TimeSpan _
    public void SetExpirationMaxAge(
       TimeSpan expirationMaxAge
    Parameters
    expirationMaxAge
    Exceptions
    ExceptionDescription
    Remarks
    You need to set SetExpirationMethod to RowExpirationMethod.MaxAge to get that in effect.
    When RealtimeFeatureClassDefinition.HasTrackIDField is true, it represents maximum age within each track. Previous observations that are older than the maximum expiration age comparing to the latest observation in the same track, will be removed.
    When RealtimeFeatureClassDefinition.HasTrackIDField is false, features older than the maximum expiration age, comparing to the current time, will get removed.
    If you don't want any features removed, set this value to 0.
    Requirements
