Public Sub SetExpirationMaxCount( _ ByVal expirationMaxCount As ULong _ )
public void SetExpirationMaxCount( ulong expirationMaxCount )
Parameters
- expirationMaxCount
- The values indicating how many features will be stored at any given time.
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
You need to set SetExpirationMethod to RowExpirationMethod.MaxCount to get that in effect.
When RealtimeFeatureClassDefinition.HasTrackIDField is true, it represents total number of features within each track.
When RealtimeFeatureClassDefinition.HasTrackIDField is false, it represents total number of features.
If you don't want any features removed, set this value to 0.
It uses FIFO method - the first one comes in is the first one to be removed.
