ArcGIS.Core.Geometry Namespace / DatumTransformation Class / CreateFromJson Method
The JSON string.
Example
    CreateFromJson Method (DatumTransformation)
    Creates a CompositeGeographicTransformation or CompositeHVDatumTransformation from the input JSON string.
    Syntax
    Public Shared Function CreateFromJson( _
       ByVal jsonString As String _
    ) As DatumTransformation
    public static DatumTransformation CreateFromJson(
       string jsonString
    Parameters
    jsonString
    The JSON string.
    Return Value
    Exceptions
    ExceptionDescription
    The JSON string is null or empty.
    Example
    Create Composite Geographic Transformation
      // Create singleton from wkid
      CompositeGeographicTransformation cgt =
          ArcGIS.Core.Geometry.CompositeGeographicTransformation.Create(108272);
      int count = cgt.Count;    // count = 1
      IList<GeographicTransformation> gts = cgt.Transformations
                                      as IList<GeographicTransformation>;
      gts.Add(ArcGIS.Core.Geometry.GeographicTransformation.Create(1437, false));
      count = cgt.Count;        // count = 2
      // create from an enumeration
      CompositeGeographicTransformation another_cgt =
                    ArcGIS.Core.Geometry.CompositeGeographicTransformation.Create(gts);
      GeographicTransformation gt0 = another_cgt[0];
      GeographicTransformation gt1 = another_cgt[1];
      // get the inverse
      CompositeGeographicTransformation inversed_cgt = another_cgt.GetInverse() as CompositeGeographicTransformation;
      // inversed_cgt[0] is same as gt1
      // inversed_cgt[1] is same as gt0
      var wkt = gt0.Wkt;
      // create from string
      CompositeGeographicTransformation third_cgt =
         ArcGIS.Core.Geometry.CompositeGeographicTransformation.Create(wkt, gt0.IsForward);
      count = third_cgt.Count;        // count = 1
      // create from josn
      string json = cgt.ToJson();
      CompositeGeographicTransformation joson_cgt =
        DatumTransformation.CreateFromJson(json) as CompositeGeographicTransformation;
    Create Composite HV Datum Transformation
      HVDatumTransformation hv1 = HVDatumTransformation.Create(108034);
      HVDatumTransformation hv2 = HVDatumTransformation.Create(108033, false);
      List<HVDatumTransformation> hvs = new List<HVDatumTransformation>() { hv1, hv2 };
      // create from enumeration
      CompositeHVDatumTransformation compositehv =
                      CompositeHVDatumTransformation.Create(hvs);
      int count = compositehv.Count;      // count = 2
      List<HVDatumTransformation> transforms =
                     compositehv.Transformations as List<HVDatumTransformation>;
      HVDatumTransformation tranform = transforms[0];
      // transform.Wkid = 108034
      // get inverse
      CompositeHVDatumTransformation inverse_compositehv =
             compositehv.GetInverse() as CompositeHVDatumTransformation;
      // create from xml
      string xml = compositehv.ToXml();
      var xml_compositehv = CompositeHVDatumTransformation.CreateFromXml(xml);
      // create from json
      string json = compositehv.ToJson();
      CompositeHVDatumTransformation json_compositehv =
          DatumTransformation.CreateFromJson(json) as CompositeHVDatumTransformation;
    Requirements
