ArcGIS.Desktop.Core Namespace / IItemFactory Interface / IsCustomItem Method / IsCustomItem(String) Method
The path to check
    Determines whether the path points to a custom item or not.
    Syntax
    bool IsCustomItem(
       string uri
    Overloads Function IsCustomItem( _
       ByVal uri As String _
    ) As Boolean
    Parameters
    uri
    The path to check
    Return Value
    True if the path points to a custom item
    Exceptions
    ExceptionDescription
    Throw when invalid characters are present in the path.
    Remarks
    The function uses the file extension of the path to compare with custom items file extensions read from currently loaded add-ins
    Requirements
