ArcGIS.Core.Data Namespace / CoreDataExtensions Class / GetDataConnections Method
The enumeration of datasets to get the CIMDataConnections for.
    Gets the CIMDataConnections for the specified datasets. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Shared Function GetDataConnections( _
       ByVal datasets As IEnumerable(Of Dataset) _
    ) As IReadOnlyList(Of CIMDataConnection)
    public static IReadOnlyList<CIMDataConnection> GetDataConnections(
       IEnumerable<Dataset> datasets
    Parameters
    datasets
    Return Value
    Exceptions
    ExceptionDescription
    No CIMDataConnection can be found for a Knowledge Graph dataset.
    A dataset does not have an associated data store because it is either invalid, virtual or currently not supported.
    Requirements
    ArcGIS Pro version: 3.4 or higher.
