ArcGIS.Desktop.Mapping Namespace / KnowledgeGraphLayer Class / CanRemoveLayers Method
An enumerable of Layers to be removed.
    CanRemoveLayers Method (KnowledgeGraphLayer)
    Determines if the layers can be removed from the container. Sublayers can be removed only if the knowledgegraph layer is on a map.
    Syntax
    public bool CanRemoveLayers(
       IEnumerable<Layer> layers
    Public Function CanRemoveLayers( _
       ByVal layers As IEnumerable(Of Layer) _
    ) As Boolean
    Parameters
    layers
    Return Value
    True if the layers can be removed. False otherwise.
    Requirements
    ArcGIS Pro version: 3.4 or higher.
