ArcGIS.Desktop.Mapping Namespace / ILayerFactory Interface / CreateLayers Method / CreateLayers(IEnumerable<Uri>,ILayerContainerEdit,Int32) Method
The set of URIs that represent the path to a set of datasets.
A map or group layer where the Layers will be added.
The position of the first Layer in the map or group layer. 0 represents the top most position.
Example
    Creates a readonly list of new Layer instances for each of the specified dataset paths and adds them to a container such as a map. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    dataUris
    container
    index
    Return Value
    A Readonly list of Layer.
    Remarks
    The bulk layer creation process creates the layers it is able to per the data supplied. If invalid Uris, data connections or Items exist amongst valid data, there will be a mismatch in the number of layers created compared to the number of data items supplied. For example, 5 Uris are supplied, but only 4 layers are created because one of the Uris points to a dataset that does not exist. LayerFactory.CreateLayers will return the layers created, but no information regarding the invalid dataset. The only exception to this is if all datasets are invalid (and no layers are created); in this scenario an System.ArgumentException will be thrown.
    Example
    Create multiple layers
      //Define a list of dataset URIs for the layers to be created
      var uriShp = new Uri(@"c:\data\roads.shp");
      var uriSde = new Uri(@"c:\MyDataConnections\MySDE.sde\Census");
      var uri = new Uri(@"http://sampleserver6.arcgisonline.com/arcgis/rest/services/NapervilleShelters/FeatureServer/0");
      // Create a list of URIs to be used for creating multiple layers
      var uris = new List<Uri>() { uriShp, uriSde, uri };
      // Create multiple layers using the LayerFactory
      var layers = await QueuedTask.Run(() => LayerFactory.Instance.CreateLayers(uris, map));
    Create multiple layers in bulk - simple
    Requirements
    ArcGIS Pro version: 3.4 or higher.
