ArcGIS.Desktop.Reports Namespace / Report Class / ExportToPDF Method
Output file name.
Provides PDFFormat export options.
Report export options.
Use the MapMember selection. If set to false, will override the default behavior and force all records to be exported.
Example
    ExportToPDF Method
    Export a report to a PDF format. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    outputName
    Output file name.
    exportFormat
    reportExportOptions
    useSelection
    Exceptions
    ExceptionDescription
    Invalid Export Format parameter.
    A valid file path could not be resolved.
    Example
    Export a layout to PDF
      //Export a single page layout to PDF.
      //Create a PDF format with appropriate settings
      //BMP, EMF, EPS, GIF, JPEG, PNG, SVG, TGA, and TFF formats are also available for export
      string filePath = @"Path and file name for the output export file";
      PDFFormat PDF = new PDFFormat()
        OutputFileName = filePath,
        Resolution = 300,
        DoCompressVectorGraphics = true,
        DoEmbedFonts = true,
        HasGeoRefInfo = true,
        ImageCompression = ImageCompression.Adaptive,
        ImageQuality = ImageQuality.Best,
        LayersAndAttributes = LayersAndAttributes.LayersAndAttributes
      //Check to see if the path is valid and export
      if (PDF.ValidateOutputFilePath())
        //Note: Must be on QueuedTask.Run
        layout.Export(PDF);  //Export the layout to PDF on the worker thread
    Export a map series to single PDF
      //Export a map series with multiple pages to a single PDF.
      //Create PDF format with appropriate settings
      PDFFormat MS_PDF = new PDFFormat()
        Resolution = 300,
      //Set up map series export options
      MapSeriesExportOptions MS_ExportOptions = new MapSeriesExportOptions()
        ExportPages = ExportPages.Custom,  //Provide a specific list of pages
        CustomPages = "1-3, 5",  //Only used if ExportPages.Custom is set
        ExportFileOptions = ExportFileOptions.ExportAsSinglePDF,  //Export all pages to a single, multi-page PDF
        ShowSelectedSymbology = false  //Do no show selection symbology in the output
      //Export on the worker thread
      if (MS_PDF.ValidateOutputFilePath())
        layout.Export(MS_PDF, MS_ExportOptions);  //Export to PDF
    Export report to pdf
      //Note: Call within QueuedTask.Run()
      //Define Export Options
      var exportOptions = new ReportExportOptions
        ExportPageOption = ExportPageOptions.ExportAllPages,
        TotalPageNumberOverride = 0
      string path = $@"{Project.Current.HomeFolderPath}\ReportExport.pdf";
      PDFFormat pdfFormat = new PDFFormat();
      pdfFormat.Resolution = 300;
      pdfFormat.OutputFileName = path;
      report.ExportToPDF($"{report.Name}", pdfFormat, exportOptions, true);
    Requirements
