ArcGIS.Desktop.Mapping Namespace / BuildingSceneLayer Class / GetFilter Method
The filter id of the filter to retrieve
Example
    GetFilter Method (BuildingSceneLayer)
    Gets a filter for the given filter id This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetFilter( _
       ByVal filterID As String _
    ) As FilterDefinition
    public FilterDefinition GetFilter(
       string filterID
    Parameters
    filterID
    Return Value
    Exceptions
    ExceptionDescription
    filter not found
    Remarks
    If a filter with the given filter id is not found a System.ArgumentException is thrown. Refer to HasFilter
    Example
    Get BuildingSceneLayer Filter ID and Filter
      var filterDefinition = bsl.GetFilter(filterID);
      //or via Linq
      //var filter = bsl.GetFilters().FirstOrDefault(f => f.ID == filterID1);
    Requirements
