ArcGIS.Desktop.Mapping Namespace / BuildingSceneLayer Class / RemoveFilter Method
The filter id of the filter to remove
Example
    RemoveFilter Method
    Removes the filter with the given filter id. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub RemoveFilter( _
       ByVal filterID As String _
    public void RemoveFilter(
       string filterID
    Parameters
    filterID
    Exceptions
    ExceptionDescription
    filter not found
    Remarks
    If a filter with the given filter id is not found a System.ArgumentException is thrown. Refer to HasFilter
    If the filter to be removed is currently the active filter, it is cleared first.
    Example
    Remove BuildingSceneLayer Filter
      // Note: call within QueuedTask.Run()
        //Note: Use HasFilter to check if a given filter id exists in the layer
        if (bsl.HasFilter(filter.ID))
          bsl.RemoveFilter(filter.ID);
        //Or remove all filters
        bsl.RemoveAllFilters();
    Requirements
