Parameters
- filterID
- The filter id of the filter to set active
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
| System.ArgumentException | filter not found |
// Note: call within QueuedTask.Run()
//Note: Use HasFilter to check if a given filter id exists in the layer
if (bsl.HasFilter(filter.ID))
bsl.SetActiveFilter(filter.ID);
var activeFilter = bsl.GetActiveFilter();
//Clear the active filter
bsl.ClearActiveFilter();
//refer to "Query Building Scene Layer for available Types and Values
var dict = bsl.GetAvailableFieldsAndValues();
var categories = dict.SingleOrDefault(kvp => kvp.Key == "Category").Value;
//get a list of existing floors or "levels"
var floors = dict.SingleOrDefault(kvp => kvp.Key == "BldgLevel").Value;
//Make a new filter definition
var fd = new FilterDefinition()
Name = "Floor and Category Filter",
Description = "Example filter",
//Set up the values for the filter
var filtervals = new Dictionary<string, List<string>>();
filtervals.Add("BldgLevel", new List<string>() { floors[0] });
var category_vals = categories.Where(v => v == "Walls" || v == "Stairs").ToList() ?? new List<string>();
if (category_vals.Count() > 0)
filtervals.Add("Category", category_vals);
//Create a solid block (other option is "Wireframe")
var fdef = new FilterBlockDefinition()
FilterBlockMode = Object3DRenderingMode.None,
Title = "Solid Filter",
SelectedValues = filtervals//Floor and Category
//Apply the block
fd.FilterBlockDefinitions = new List<FilterBlockDefinition>() { fdef };
//Add the filter definition to the layer
bsl.UpdateFilter(fd);
//Set it active. The ID is auto-generated
bsl.SetActiveFilter(fd.ID);
