ArcGIS.Desktop.Mapping Namespace / FeatureSceneLayer Class / GetFeatureClass Method
Example
    GetFeatureClass Method (FeatureSceneLayer)
    Gets the associated feature class. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public FeatureClass GetFeatureClass()
    Public Function GetFeatureClass() As FeatureClass
    Return Value
    Exceptions
    ExceptionDescription
    No associated feature service
    Remarks
    Only FeatureSceneLayers with an associated feature service can return a feature class. Check HasAssociatedFeatureService property to determine if the FeatureSceneLayer has an associated feature service. Calling GetFeatureClass() on a FeatureSceneLayer with no associated feature service will throw a System.InvalidOperationException
    Example
    Get the Associated Feature class
      await QueuedTask.Run(() =>
        if (featSceneLayer.HasAssociatedFeatureService)
          using (var fc = featSceneLayer.GetFeatureClass())
            //TODO query underlying feature class
    Use Select or Search with a Spatial Query
      var mapView = MapView.Active;
      if (mapView == null)
        return;
        if (!featSceneLayer.HasAssociatedFeatureService)
          return;//no search or select
        //Select all features within the current map view
        var sz = mapView.GetViewSize();
        var map_pt1 = mapView.ClientToMap(new System.Windows.Point(0, sz.Height));
        var map_pt2 = mapView.ClientToMap(new System.Windows.Point(sz.Width, 0));
        //Convert to an envelope
        var temp_env = EnvelopeBuilderEx.CreateEnvelope(map_pt1, map_pt2, mapView.Map.SpatialReference);
        //Project if needed to the layer spatial ref
        SpatialReference sr = null;
        using (var fdef = fc.GetDefinition())
          sr = fdef.GetSpatialReference();
        var env = GeometryEngine.Instance.Project(temp_env, sr) as Envelope;
        //Set up a query filter
        var sf = new SpatialQueryFilter()
          FilterGeometry = env,
          SpatialRelationship = SpatialRelationship.Intersects,
          SubFields = "*"
        //Select against the feature service
        var select = featSceneLayer.Select(sf);
        if (select.GetCount() > 0)
          //enumerate over the selected features
          using (var rc = select.Search())
            while (rc.MoveNext())
              using (var feature = rc.Current as Feature)
                oid = feature.GetObjectID();
                //etc.
        mapView.Map.ClearSelection();
    Requirements
