ArcGIS.Desktop.Mapping Namespace / FeatureSceneLayer Class
Members Example
    FeatureSceneLayers currently support the I3S Point and 3D Object layer types. Points must be based off 3D point data and 3D Objects must be based off multipatches.
    Object Model
    FeatureSceneLayer ClassDefinitionQuery ClassLayer ClassCIMDataConnection ClassTimeExtent ClassCIMBaseLayer ClassElevationTypeDefinition ClassFeatureClass ClassCIMRenderer ClassSelection ClassSpatialReference ClassTimeParameters ClassSurfaceZsResult ClassMap ClassILayerContainer InterfaceEnvelope ClassRowCursor ClassRowCursor ClassSelection ClassDefinitionQuery Class
    Syntax
    Example
    Create a Scene Layer
      // Note: call within QueuedTask.Run()
        //Create with initial visibility set to false. Add to current scene
        var createparams = new LayerCreationParams(new Uri(sceneLayerUrl, UriKind.Absolute))
          IsVisible = false
        //cast to specific type of scene layer being created - in this case FeatureSceneLayer
        var sceneLayer = LayerFactory.Instance.CreateLayer<Layer>(
                 createparams, MapView.Active.Map) as FeatureSceneLayer;
        //or...specify the cast directly
        var sceneLayer2 = LayerFactory.Instance.CreateLayer<FeatureSceneLayer>(
                 createparams, MapView.Active.Map);
        //ditto for BuildingSceneLayer, PointCloudSceneLayer, IntegratedMeshSceneLayer
    Name of FeatureSceneLayer
      featSceneLayer = MapView.Active.Map.GetLayersAsFlattenedList()
                       .OfType<FeatureSceneLayer>().FirstOrDefault();
      var scenelayerName = featSceneLayer?.Name;
    Use MapView Selection SelectFeaturesEx or GetFeaturesEx
      var sname = featSceneLayer.Name;
        //Select all features within the current map view
        var sz = MapView.Active.GetViewSize();
        var c_ll = new Coordinate2D(0, 0);
        var c_ur = new Coordinate2D(sz.Width, sz.Height);
        //Use screen coordinates for 3D selection on MapView
        var env = EnvelopeBuilderEx.CreateEnvelope(c_ll, c_ur);
        //HasAssociatedFeatureService does not matter for SelectFeaturesEx
        //or GetFeaturesEx
        var result = MapView.Active.SelectFeaturesEx(env);
        //var result = MapView.Active.GetFeaturesEx(env);
        //The list of object ids from SelectFeaturesEx
        var oids1 = result.ToDictionary().Where(kvp => kvp.Key.Name == sname).First().Value;
        //TODO - use the object ids
        MapView.Active.Map.ClearSelection();
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase
          ArcGIS.Desktop.Mapping.MapMember
             ArcGIS.Desktop.Mapping.Layer
                ArcGIS.Desktop.Mapping.CompositeLayer
                   ArcGIS.Desktop.Mapping.FeatureSceneLayer
    Requirements
