ArcGIS.Desktop.Mapping Namespace / FeatureSceneLayer Class / Search Method
A query filter or spatial filter
Example
    Search Method (FeatureSceneLayer)
    Search for features based upon the specified attribute and/or spatial criteria. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public RowCursor Search(
       QueryFilter queryFilter
    Public Function Search( _
       Optional ByVal queryFilter As QueryFilter _
    ) As RowCursor
    Parameters
    queryFilter
    Return Value
    Exceptions
    ExceptionDescription
    No associated feature service
    A geodatabase-related exception has occurred.
    Remarks
    Search can only be used on feature scene layers that have an associated feature service. Check HasAssociatedFeatureService property to determine if the FeatureSceneLayer has an associated feature service. Calling Search() on a FeatureSceneLayer with no associated feature service will throw a System.InvalidOperationException
    Example
    Search Rows on the FeatureSceneLayer
      if (!featSceneLayer.HasAssociatedFeatureService)
        return;//Search and Select not supported
      //Multipatch (Object3D) or point?
      //var is3dObject = ((ISceneLayerInfo)featSceneLayer).SceneServiceLayerType
      //                                  == esriSceneServiceLayerType.Object3D;
      var is3dObject = featSceneLayer.FeatureSceneLayerType == FeatureSceneLayerType.Object3D;
      await QueuedTask.Run(() =>
        var queryFilter = new QueryFilter
          WhereClause = "Name = 'Ponderosa Pine'",
          SubFields = "*"
        int rowCount = 0;
        //or select... var select = featSceneLayer.Select(queryFilter)
        using (RowCursor rowCursor = featSceneLayer.Search(queryFilter))
          while (rowCursor.MoveNext())
            using (var feature = rowCursor.Current as Feature)
              oid = feature.GetObjectID();
              var shape = feature.GetShape();
              var attrib = feature["Name"];
              if (is3dObject)
                //shape is a multipatch
              else
                //shape is a point
              rowCount += 1;
    Requirements
