ArcGIS.Desktop.Mapping Namespace / PointCloudFilterDefinition Class / ToCIM Method
Example
    ToCIM Method
    Creates a list of CIMPointCloudFilters based on the PointCloudFilterDefinition.
    Syntax
    Example
    Set a Filter for PointCloudSceneLayer
      await QueuedTask.Run(() =>
        //Retrieve the available classification codes
        var dict = pointCloudSceneLayer.GetAvailableClassCodesAndLabels();
        //Filter out low noise and unclassified (7 and 1 respectively)
        //consult https://doc.esri.com/en/arcgis-pro/latest/help/data/las-dataset/storing-lidar-data.html
        var filterDef = new PointCloudFilterDefinition()
          ClassCodes = dict.Keys.Where(c => c != 7 && c != 1).ToList(),
          ReturnValues = new List<PointCloudReturnType> {
                            PointCloudReturnType.FirstOfMany }
        //apply the filter
        pointCloudSceneLayer.SetFilters(filterDef.ToCIM());
    Update the ClassFlags for PointCloudSceneLayer
        var filters = pointCloudSceneLayer.GetFilters();
        PointCloudFilterDefinition fdef = null;
        if (filters.Count() == 0)
          fdef = new PointCloudFilterDefinition()
            //7 is "edge of flight line" - exclude
            ClassFlags = new List<ClassFlag> {
             new ClassFlag(7, ClassFlagOption.Exclude) }
        else
          fdef = PointCloudFilterDefinition.FromCIM(filters);
          //keep any include or ignore class flags
          var keep = fdef.ClassFlags.Where(
                 cf => cf.ClassFlagOption != ClassFlagOption.Exclude).ToList();
          keep.Add(new ClassFlag(7, ClassFlagOption.Exclude));
          fdef.ClassFlags = keep;
        //apply
        pointCloudSceneLayer.SetFilters(fdef.ToCIM());
    Requirements
