ArcGIS.Desktop.Mapping Namespace / PointCloudRendererDefinition Class
Members
    A point cloud renderer definition for creating a ArcGIS.Core.CIM.CIMPointCloudRenderer.
    Syntax
    Public Class PointCloudRendererDefinition
       Inherits RendererDefinition
    public class PointCloudRendererDefinition : RendererDefinition
    Remarks
    Convert a point cloud renderer definition to a CIMPointCloudRenderer using the PointCloudSceneLayer.CreateRenderer method.
    Use PointCloudSceneLayer.GetAvailablePointCloudRendererFields to check whether or not a point cloud layer contains (one of) the necessary field(s) to support the given renderer. There are up to five fields that could be available for rendering depending on the given layer:
    1. ELEVATION: can be used with Stretch and ClassBreaks
    2. CLASS_CODE: LAS classification codes, can be used with Unique Value
    3. RETURNS: Lidar pulse return number, can be used with Unique Value
    4. RGB: can be used with RGB
    5. INTENSITY: can be used with Stretch and ClassBreaks
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Mapping.LayerDrawingDefinition
          ArcGIS.Desktop.Mapping.RendererDefinition
             ArcGIS.Desktop.Mapping.PointCloudRendererDefinition
    Requirements
