ArcGIS.Desktop.Mapping Namespace / PointCloudSceneLayer Class / CreateRenderer Method
Input RendererDefinition
Example
    CreateRenderer Method (PointCloudSceneLayer)
    Creates a CIMPointCloudRenderer from a PointCloudRendererDefinition for use with SetRenderer . This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Exceptions
    ExceptionDescription
    rendererDefinition
    Example
    Create and Set a Stretch Renderer
      // Note: call within QueuedTask.Run()
        var fields = pointCloudSceneLayer.GetAvailablePointCloudRendererFields(
                                PointCloudRendererType.StretchRenderer);
        var stretchDef = new PointCloudRendererDefinition(
          //Will be either ELEVATION or INTENSITY
          Field = fields[0]
        //Create the CIM Renderer
        var stretchRenderer = pointCloudSceneLayer.CreateRenderer(stretchDef)
                                            as CIMPointCloudStretchRenderer;
        //Apply a color ramp
        var style = Project.Current.GetItems<StyleProjectItem>()
                                        .First(s => s.Name == "ArcGIS Colors");
        var colorRamp = style.SearchColorRamps("").First();
        stretchRenderer.ColorRamp = colorRamp.ColorRamp;
        //Apply modulation
        stretchRenderer.ColorModulation = new CIMColorModulationInfo()
          MinValue = 0,
          MaxValue = 100
        //apply the renderer
        pointCloudSceneLayer.SetRenderer(stretchRenderer);
    Create and Set a ClassBreaks Renderer
                           PointCloudRendererType.ClassBreaksRenderer);
        var classBreakDef = new PointCloudRendererDefinition(
          //ELEVATION or INTENSITY
          Field = fields[0]
        //create the renderer
        var cbr = pointCloudSceneLayer.CreateRenderer(classBreakDef)
                                  as CIMPointCloudClassBreaksRenderer;
        //Set up a color scheme to use
        var rampStyle = style.LookupItem(
          StyleItemType.ColorRamp, "Spectrum By Wavelength-Full Bright_Multi-hue_2")
        as ColorRampStyleItem;
        var colorScheme = rampStyle.ColorRamp;
        //Set up 6 manual class breaks
        var breaks = 6;
        var colors = ColorFactory.Instance.GenerateColorsFromColorRamp(
                                                    colorScheme, breaks);
        var classBreaks = new List<CIMColorClassBreak>();
        var min = cbr.Breaks[0].UpperBound;
        var max = cbr.Breaks[cbr.Breaks.Count() - 1].UpperBound;
        var step = (max - min) / (double)breaks;
        //add in the class breaks
        double upper = min;
        for (int b = 1; b <= breaks; b++)
          double lower = upper;
          upper = b == breaks ? max : min + (b * step);
          var cb = new CIMColorClassBreak()
            UpperBound = upper,
            Label = string.Format("{0:#0.0#} - {1:#0.0#}", lower, upper),
            Color = colors[b - 1]
          classBreaks.Add(cb);
        cbr.Breaks = classBreaks.ToArray();
        pointCloudSceneLayer.SetRenderer(cbr);
    Requirements
