ArcGIS.Core.CIM Namespace / CIMAggregateField Class
Properties Methods Events
    CIMAggregateField Class Members
    The following tables list the members exposed by CIMAggregateField.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the field name on which the aggregation was done.
    Public Property Gets or sets the field alias. (Inherited from ArcGIS.Core.CIM.CIMFieldDescription)
    Public Property Gets or sets the field name. (Inherited from ArcGIS.Core.CIM.CIMFieldDescription)
    Public Property Gets or sets a value indicating whether the field is highlighted. (Inherited from ArcGIS.Core.CIM.CIMFieldDescription)
    Public Property Gets or sets the number format. (Inherited from ArcGIS.Core.CIM.CIMFieldDescription)
    Public Property Gets or sets a value indicating whether the field is read only. (Inherited from ArcGIS.Core.CIM.CIMFieldDescription)
    Public Property Gets or sets a value indicating whether the values from this field should be included in the search. (Inherited from ArcGIS.Core.CIM.CIMFieldDescription)
    Public Property Gets or sets search mode to use when searching for values in this field. (Inherited from ArcGIS.Core.CIM.CIMFieldDescription)
    Public Property Gets or sets the type of statistic used to aggregate data.
    Public Property Gets or sets a value indicating whether the field value is a ratio (used only by geoprocessing). (Inherited from ArcGIS.Core.CIM.CIMFieldDescription)
    Public Property Gets or sets a value indicating whether the field is visible. (Inherited from ArcGIS.Core.CIM.CIMFieldDescription)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMAggregateField.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMAggregateField with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMAggregateField and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
