ArcGIS.Core.CIM Namespace / CIMHuffModelDistanceParameters Class
Properties Methods Events
    CIMHuffModelDistanceParameters Class Members
    The following tables list the members exposed by CIMHuffModelDistanceParameters.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets data source used in calculation of distances. Structure of the value is TYPE;COUNTRY_INFO;LOCAL_DATA_INFO where TYPE can be ONLINE, LOCAL, or CUSTOM. COUNTRY_INFO is country_id{|hierarchy}. For example, US|census or US. LOCAL_DATA_INFO is ID of local dataset. For example, USA_ESRI_2019. For example, for local US 2019 dataset it will be: "LOCAL;;USA_ESRI_2019". If online US data source is used, it may be "ONLINE;US|census;". Can be value of baDataSource GP GPEnvironment variable. https://pro.arcgis.com/en/pro-app/tool-reference/environment-settings/ba-data-source.htm.
    Public Property Gets or sets distance units used in calculation of distances.
    Public Property Gets or sets the exponent.
    Public Property Gets or sets time of day used in calculation of distances.
    Public Property Gets or sets time units used in calculation of distances.
    Public Property Gets or sets time zone used in calculation of distances.
    Public Property Gets or sets a value indicating whether to calculate distances toward facilities.
    Public Property Gets or sets ID of travel mode used in calculation of distances.
    Public Property Gets or sets a value indicating whether to use network dataset to calculate distances.
    Public Property Gets or sets a value indicating whether to use time units.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMHuffModelDistanceParameters.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMHuffModelDistanceParameters with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMHuffModelDistanceParameters and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
