ArcGIS.Core.CIM Namespace / CIMRasterMultidimensionalDisplayDefinition Class
Properties Methods Events
    CIMRasterMultidimensionalDisplayDefinition Class Members
    The following tables list the members exposed by CIMRasterMultidimensionalDisplayDefinition.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the additional range dimension values for the current display slice.
    Public Property Gets or sets a value indicating whether the active variable has a range dimension.
    Public Property Gets or sets the name of the selected range dimension.
    Public Property Gets or sets the selected range dimension value for the current display slice.
    Public Property Gets or sets the time value for the current display slice.
    Public Property Gets or sets the name of the variable.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMRasterMultidimensionalDisplayDefinition.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMRasterMultidimensionalDisplayDefinition with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMRasterMultidimensionalDisplayDefinition and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
