ArcGIS.Core.Geometry Namespace / MapPointBuilderEx Class / MapPointBuilderEx Constructor / MapPointBuilderEx Constructor(Double,Double,Boolean,Double,Boolean,Double,Boolean,Int32,SpatialReference)
The X-value.
The Y-value.
If true, the Z-value is set and HasZ is true.
The Z-value which is used only if hasZ is true.
If true, the M-value is set and HasM is true.
The M-value which is used only if hasM is true.
If true, the ID value is set and HasID is true.
The ID-value which is used only if hasId is true.
(Optional) The SpatialReference. The default value is null.
    Creates a new MapPointBuilderEx instance with the given X and Y coordinates and other attributes.
    Syntax
    Public Function New( _
       ByVal x As Double, _
       ByVal y As Double, _
       ByVal hasZ As Boolean, _
       ByVal z As Double, _
       ByVal hasM As Boolean, _
       ByVal m As Double, _
       ByVal hasId As Boolean, _
       ByVal id As Integer, _
       Optional ByVal spatialReference As SpatialReference _
    Parameters
    x
    The X-value.
    y
    The Y-value.
    hasZ
    z
    hasM
    m
    hasId
    id
    spatialReference
    Requirements
