ArcGIS.Desktop.Editing Namespace / EditOperation Class / AddAttachment Method / AddAttachment(RowToken,String) Method
The RowToken representing the future row to add the attachment to.
The filesystem path to the file to attach to the row.
Example
    Add an attachment to a row with attachment support.
    Syntax
    Public Overloads Sub AddAttachment( _
       ByVal token As RowToken, _
       ByVal filePath As String _
    public void AddAttachment(
       RowToken token,
       string filePath
    Parameters
    token
    filePath
    Remarks
    This method is used to add an attachment to a future row returned from the EditOperation.Create method. The RowToken allows a row to be created and the attachment added within the same EditOperation, without the need for chaining.
    Example
    Edit Operation add attachment via RowToken
    // Creates a new feature using the specified editing template and polygon geometry, and adds an attachment to the feature in a single edit operation.
    await QueuedTask.Run(() =>
        //The EditOperation.AddAttachment method to take a RowToken as a parameter
        //allows you to create a feature, using EditOperation.CreateEx, and add an attachment in one transaction.
        EditOperation editOpAttach = new()
          Name = string.Format($@"Create new polygon with attachment in '{currentTemplate.Layer.Name}'")
        var attachRowToken = editOpAttach.Create(currentTemplate, polygon);
        editOpAttach.AddAttachment(attachRowToken, @"c:\temp\image.jpg");
        //Must be within a QueuedTask
        if (!editOpAttach.IsEmpty)
          //Execute and ExecuteAsync will return true if the operation was successful and false if not
          var result = editOpAttach.Execute();
    Requirements
