ArcGIS.Desktop.Mapping Namespace / MappingExtensions Class / AddOverlayAsync Method / AddOverlayAsync(MapView,Layer,Int64,CIMSymbolReference,Double) Method
The view to add the overlay.
The layer containing the feature.
The ObjectID for the feature.
The symbol to use for the overlay.
Map reference scale or -1
    Add an overlay graphic for a feature on the map view. This is only supported in 2D.
    Syntax
    Public Overloads Shared Function AddOverlayAsync( _
       ByVal mapView As MapView, _
       ByVal layer As Layer, _
       ByVal oid As Long, _
       Optional ByVal symbol As CIMSymbolReference, _
       Optional ByVal referenceScale As Double _
    ) As Task(Of IDisposable)
    Parameters
    mapView
    layer
    oid
    symbol
    referenceScale
    Return Value
    An object that when disposed will remove the overlay.
    Remarks
    When the referenceScale is not equal to -1, the overlay will be created in real world units relative to the provided map reference scale (referenceScale). Otherwise, the overlay will be created in units of points. This is only supported in 2D.
    Requirements
