ArcGIS.Desktop.Mapping Namespace / MapTool Class / AddOverlayAsync Method / AddOverlayAsync(Layer,Int64,CIMSymbolReference,Double) Method
The layer containing the feature.
The ObjectID for the feature.
The symbol to use for the overlay.
Map reference scale or -1
    Add an overlay graphic for a feature on the map view.
    Syntax
    Protected Overloads Function AddOverlayAsync( _
       ByVal layer As Layer, _
       ByVal oid As Long, _
       Optional ByVal symbol As CIMSymbolReference, _
       Optional ByVal referenceScale As Double _
    ) As Task(Of IDisposable)
    Parameters
    layer
    oid
    symbol
    referenceScale
    Return Value
    An object that when disposed will remove the overlay.
    Remarks
    When the tool is deactivated all overlay graphics will be removed.When the referenceScale is not equal to -1, the overlay will be created in real world units relative to the provided map reference scale (referenceScale). Otherwise, the overlay will be created in units of points. This is only supported in 2D.
    Requirements
