ArcGIS.Desktop.Mapping Namespace / IMapFactory Interface / CreateMap Method / CreateMap(Uri) Method
The uri to the package or file
    Creates a new Map in the project from a map package or file Uri. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Overloads Function CreateMap( _
       ByVal dataUri As Uri _
    ) As Map
    Map CreateMap(
       Uri dataUri
    Parameters
    dataUri
    Return Value
    A map.
    Exceptions
    ExceptionDescription
    The dataUri is null.
    Remarks
    To open a map, use ProApp.Panes.CreateMapPaneAsync method.
    To create a link chart use MapFactory.CreateLinkChart./>.
    Requirements
