ArcGIS.Core.CIM Namespace / CIMBAVariableBasedCriterion Class / DataSource Property
    DataSource Property (CIMBAVariableBasedCriterion)
    Gets or sets the data source used in calculation of distances. Structure of the value is TYPE;COUNTRY_INFO;LOCAL_DATA_INFO where TYPE can be ONLINE, LOCAL, or CUSTOM. COUNTRY_INFO is country_id{|hierarchy}. For example, US|census or US. LOCAL_DATA_INFO is ID of local dataset. For example, USA_ESRI_2019. For example, for local US 2019 dataset it will be: "LOCAL;;USA_ESRI_2019". If online US data source is used, it may be "ONLINE;US|census;". Can be value of baDataSource GP GPEnvironment variable. https://pro.arcgis.com/en/pro-app/tool-reference/environment-settings/ba-data-source.htm.
    Syntax
    public string DataSource {get; set;}
    Public Property DataSource As String
    Requirements
    ArcGIS Pro version: 3.4 or higher.
