ArcGIS.Core.CIM Namespace / CIMBivariateFieldInfo Class
Properties Methods Events
    CIMBivariateFieldInfo Class Members
    The following tables list the members exposed by CIMBivariateFieldInfo.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the classification method.
    Public Property Gets or sets the default label used for the legend.
    Public Property Gets or sets the field for rendering.
    Public Property Gets or sets the minimum break.
    Public Property Gets or sets the normalization field.
    Public Property Gets or sets the normalization total.
    Public Property Gets or sets the normalization type.
    Public Property Gets or sets the number of bins displayed in the histogram.
    Public Property Gets or sets the collection of upper bounds.
    Public Property Gets or sets ExpressionInfo that contains the Arcade expression that returns value as a number. When both Field and ValueExpressionInfo are present ValueExpressionInfo is used.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMBivariateFieldInfo.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMBivariateFieldInfo with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMBivariateFieldInfo and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
