ArcGIS.Core.CIM Namespace / CIMLocator Class
Properties Methods Events
    CIMLocator Class Members
    The following tables list the members exposed by CIMLocator.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether or not to this locator is enabled.
    Public Property Gets or sets the type of locator for the LocatorURI specified.
    Public Property Gets or sets locator source URI. It can either be a local path, URL or a layer URI from this map. e.g. file://<folder_path>, http://<url>, CIMPATH=<cim_layer_UR>.
    Public Property Gets or sets the name of the locator.
    Public Property Gets or sets a value indicating whether or not to suggestions should enabled if the locator supports suggestions.
    Public Property Gets or sets a value indicating whether the locator supports suggestions.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMLocator.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMLocator with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMLocator and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
