ArcGIS.Core.CIM Namespace / CIMCustomGridLabelTemplate Class
Properties Methods Events
    CIMCustomGridLabelTemplate Class Members
    The following tables list the members exposed by CIMCustomGridLabelTemplate.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the list of label angles to set the text symbol angle for each grid edge.
    Public Property Gets or sets the label expression. Either a simple field name or an Arcade expression.
    Public Property Gets or sets the symbol of the label.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMCustomGridLabelTemplate.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMCustomGridLabelTemplate with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMCustomGridLabelTemplate and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
