ArcGIS.Core.CIM Namespace / CIMMap Class / DatumTransforms Property
Example
    Gets or sets the set of geographic transformations used by the map for spatial references that do not have vertical coordinate system.
    Syntax
    public CIMDatumTransform[] DatumTransforms {get; set;}
    Public Property DatumTransforms As CIMDatumTransform()
    Example
    Datum
      var cimMapDefinition = MapView.Active.Map.GetDefinition();
      // use if map's sr does not have a vertical coordinate system
      var datumTransformations = cimMapDefinition.DatumTransforms;
      // use if map's sr has a vertical coordinate system
      var hvDatumTransformations = cimMapDefinition.HVDatumTransforms;
    Requirements
