ArcGIS.Core.CIM Namespace / CIMVoxelStretchRenderer Class / ColorRangeMin Property
Example
    Gets or sets the minimum value.
    Syntax
    Public Property ColorRangeMin As Double
    public double ColorRangeMin {get; set;}
    Example
    Access Stats and Color Range for a Stretch Renderer
      //Get the variable profile on which to access the data
      var variable = voxelLayer.SelectedVariableProfile;
      //or use ...voxelLayer.GetVariableProfiles()
      //Data range
      var min = variable.Statistics.MinimumValue;
      var max = variable.Statistics.MaximumValue;
      //Color range (Continuous only)
      double color_min, color_max;
      if (variable.DataType == VoxelVariableDataType.Continuous)
        var renderer = variable.Renderer as CIMVoxelStretchRenderer;
        color_min = renderer.ColorRangeMin;
        color_max = renderer.ColorRangeMax;
    Change Stretch Renderer Color Range
      //Typically, the default color range covers the most
      //commonly occurring voxel values. Usually, the data
      //range is much broader than the color range
      // Note: call within QueuedTask.Run()
        //Get the variable profile whose renderer will be changed
        //Check DataType
        if (variable.DataType != VoxelVariableDataType.Continuous)
          //must be continuous to have a Stretch Renderer...
        var color_min = renderer.ColorRangeMin;
        var color_max = renderer.ColorRangeMax;
        //increase range by 10% of the current difference
        var dif = (color_max - color_min) * 0.05;
        color_min -= dif;
        color_max += dif;
        //make sure we do not exceed data range
        if (color_min < variable.Statistics.MinimumValue)
          color_min = variable.Statistics.MinimumValue;
        if (color_max > variable.Statistics.MaximumValue)
          color_max = variable.Statistics.MaximumValue;
        //variable.Statistics.MinimumValue
        renderer.ColorRangeMin = color_min;
        renderer.ColorRangeMax = color_max;
        //apply changes
        variable.SetRenderer(renderer);
    Requirements
