ArcGIS.Core.CIM Namespace / CIMVoxelStretchRenderer Class
Properties Methods Events
    CIMVoxelStretchRenderer Class Members
    The following tables list the members exposed by CIMVoxelStretchRenderer.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the color ramp of the renderer.
    Public Property Gets or sets the maximum value.
    Public Property Gets or sets the minimum value.
    Public Property Gets or sets the heading.
    Public Property Gets or sets the interpolation mode.
    Public Property Gets or sets a value indicating whether data filter is enabled.
    Public Property Gets or sets the legend label for the maximum color range value.
    Public Property Gets or sets the legend label for the minimum color range value.
    Public Property Gets or sets the number format.
    Public Property Gets or sets a value indicating whether the histogram shows the full data range.
    Public Property Gets or sets the transparency stop positions.
    Public Property Gets or sets the transparency stop values.
    Public Property Gets or sets a value indicating whether transparency stops are used.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMVoxelStretchRenderer.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMVoxelStretchRenderer with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMVoxelStretchRenderer and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
