Use the SetIsEditingEnabledAsync method to enable or disable editing within the application.
// Enables editing for the current project asynchronously. if (!Project.Current.IsEditingEnabled) { var bEditingIsEnabled = await Project.Current.SetIsEditingEnabledAsync(true); }
// Disables editing for the current project. // discard any edits if they exist var discardEdits = true; // only needed if editing is enabled if (Project.Current.IsEditingEnabled) { // check for edits if (Project.Current.HasEdits) { if (discardEdits) await Project.Current.DiscardEditsAsync(); else await Project.Current.SaveEditsAsync(); } var bEditingIsEnabled = !Project.Current.SetIsEditingEnabledAsync(false).Result; }
// ApplicationOptions.EditingOptions.EnableEditingFromEditTab is true
// ApplicationOptions.EditingOptions.IsSingleWorkspaceEditSession is true
var project = Project.Current;
// check if already editing
if (project.IsEditingEnabled)
// save or discard any edits
if (project.HasEdits)
var res = MessageBox.Show("Save edits?", "Save Edits?", System.Windows.MessageBoxButton.YesNoCancel);
if (res == System.Windows.MessageBoxResult.Cancel)
return;
else if (res == System.Windows.MessageBoxResult.No)
await project.DiscardEditsAsync();
else
await project.SaveEditsAsync();
// close the edit session
await project.SetIsEditingEnabledAsync(false);
// find a layer
var mm = MapView.Active.Map.GetLayersAsFlattenedList().FirstOrDefault(l => l.Name == "Roads");
if (mm == null)
return;
// start the edit session on the workspace attached to the layer
var success = await project.SetSingleEditWorkspaceAsync(mm);
// if success = true then an edit session was started
// and project.IsEditingEnabled will be true
