Public Function GetGraphic() As CIMGraphic
public CIMGraphic GetGraphic()
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method must be called within the lambda passed to QueuedTask.Run. |
//Note: Must be on QueuedTask.Run
//Create rectangle text with background and border symbology.
//Build 2D polygon geometry
List<Coordinate2D> plyCoords = new List<Coordinate2D>();
plyCoords.Add(new Coordinate2D(3.5, 7));
plyCoords.Add(new Coordinate2D(4.5, 7));
plyCoords.Add(new Coordinate2D(4.5, 6.7));
plyCoords.Add(new Coordinate2D(5.5, 6.7));
plyCoords.Add(new Coordinate2D(5.5, 6.1));
plyCoords.Add(new Coordinate2D(3.5, 6.1));
Polygon poly = PolygonBuilderEx.CreatePolygon(plyCoords);
//Set symbology, create and add element to layout
//Also notice how formatting tags are using within the text string.
CIMTextSymbol sym = SymbolFactory.Instance.ConstructTextSymbol(
ColorFactory.Instance.GreyRGB, 10, "Arial", "Regular");
string text = "Some Text String that is really long and is " +
"<BOL>forced to wrap to other lines</BOL> so that " +
"we can see the effects." as String;
GraphicElement polyTxtElm = ElementFactory.Instance.CreateTextGraphicElement(
layout, TextType.RectangleParagraph, poly, sym, text, "Polygon Paragraph");
//(Optionally) Modify paragraph border
CIMGraphic polyTxtGra = polyTxtElm.GetGraphic();
CIMParagraphTextGraphic cimPolyTxtGra = polyTxtGra as CIMParagraphTextGraphic;
cimPolyTxtGra.Frame.BorderSymbol = new CIMSymbolReference();
cimPolyTxtGra.Frame.BorderSymbol.Symbol =
SymbolFactory.Instance.ConstructLineSymbol(
ColorFactory.Instance.GreyRGB, 1.0, SimpleLineStyle.Solid);
polyTxtElm.SetGraphic(polyTxtGra);
//Create a picture element and also set background and border symbology.
//Build 2D envelope geometry
Coordinate2D pic_ll = new Coordinate2D(6, 1);
Coordinate2D pic_ur = new Coordinate2D(8, 2);
Envelope env = EnvelopeBuilderEx.CreateEnvelope(pic_ll, pic_ur);
//Create and add element to layout
string picPath = @"C:\Temp\WhitePass.jpg";
GraphicElement picElm = ElementFactory.Instance.CreatePictureGraphicElement(
layout, env, picPath, "New Picture");
//(Optionally) Modify the border and shadow
CIMGraphic picGra = picElm.GetGraphic();
CIMPictureGraphic cimPicGra = picGra as CIMPictureGraphic;
cimPicGra.Frame.BorderSymbol = new CIMSymbolReference();
cimPicGra.Frame.BorderSymbol.Symbol =
ColorFactory.Instance.BlueRGB, 2.0, SimpleLineStyle.Solid);
cimPicGra.Frame.ShadowSymbol = new CIMSymbolReference();
cimPicGra.Frame.ShadowSymbol.Symbol =
SymbolFactory.Instance.ConstructPolygonSymbol(
ColorFactory.Instance.BlackRGB, SimpleFillStyle.Solid);
//Update the element
picElm.SetGraphic(picGra);
//Find elements by name
var layoutElementsToFind = layout.FindElements(new List<string>() { "Point 1", "Line 3", "Text 1" });
//Get the collection of elements from the page layout. Nesting within GroupElement is preserved.
var elementCollection = layout.GetElements();
//Get the collection of Element from the page layout as a flattened list. Nested groups within GroupElement are not preserved.
var elements = layout.GetElementsAsFlattenedList();
//Convert collection of the elements to a collection of GraphicElements.
var graphicElements = elements.ToList().ConvertAll(x => (GraphicElement)x);
//Find elements by type
//Find all point graphics in the Layout
var pointGraphics = graphicElements.Where(elem => elem.GetGraphic() is CIMPointGraphic);
//Find all line graphics in the Graphics Layer
var lineGraphics = graphicElements.Where(elem => elem.GetGraphic() is CIMLineGraphic);
////Find all polygon graphics in the Graphics Layer
var polyGraphics = graphicElements.Where(elem => elem.GetGraphic() is CIMPolygonGraphic);
////Find all text graphics in the Graphics Layer
var textGraphics = graphicElements.Where(elem => elem.GetGraphic() is CIMTextGraphic);
////Find all picture graphics in the Graphics Layer
var pictureGraphic = graphicElements.Where(elem => elem.GetGraphic() is CIMPictureGraphic);
//Update an element's transparency using the CIM.
// Reference a element by name
GraphicElement graphicElement = layout.FindElement("MyElement") as GraphicElement;
if (graphicElement != null)
// Modify the Transparency property that exists only in the CIMGraphic class.
CIMGraphic CIMGraphic = graphicElement.GetGraphic() as CIMGraphic;
CIMGraphic.Transparency = 50; // mark it 50% transparent
graphicElement.SetGraphic(CIMGraphic);
//This is the gap between two fields
double fieldIncrement = 0.9388875113593206276389;
//On the QueuedTask
//New field to add.
var newReportField = new CIMReportField
Name = "POP1990",
FieldOrder = 2,
//Get the "ReportSection element"
var mainReportSection = report.Elements.OfType<ReportSection>().FirstOrDefault();
if (mainReportSection == null) return;
//Get the "ReportDetails" within the ReportSectionElement. ReportDetails is where "fields" are.
var reportDetailsSection = mainReportSection?.Elements.OfType<ReportDetails>().FirstOrDefault();
if (reportDetailsSection == null) return;
//Within ReportDetails find the envelope that encloses a field.
//We get the first CIMParagraphTextGraphic in the collection so that we can add the new field next to it.
var lastFieldGraphic = reportDetailsSection.Elements.FirstOrDefault((r) =>
var gr = r as GraphicElement;
if (gr == null) return false;
return (gr.GetGraphic() is CIMParagraphTextGraphic ? true : false);
//Get the Envelope of the last field
var graphicBounds = lastFieldGraphic.GetBounds();
//Min and Max values of the envelope
var xMinOfFieldEnvelope = graphicBounds.XMin;
var yMinOfFieldEnvelope = graphicBounds.YMin;
var xMaxOfFieldEnvelope = graphicBounds.XMax;
var YMaxOfFieldEnvelope = graphicBounds.YMax;
//create the new Envelope to be offset from the existing field
MapPoint newMinPoint = MapPointBuilderEx.CreateMapPoint(xMinOfFieldEnvelope + fieldIncrement, yMinOfFieldEnvelope);
MapPoint newMaxPoint = MapPointBuilderEx.CreateMapPoint(xMaxOfFieldEnvelope + fieldIncrement, YMaxOfFieldEnvelope);
Envelope newFieldEnvelope = EnvelopeBuilderEx.CreateEnvelope(newMinPoint, newMaxPoint);
//Create field
GraphicElement fieldGraphic = ReportElementFactory.Instance.CreateFieldValueTextElement(reportDetailsSection, newFieldEnvelope, newReportField);
// Note: must be called on the QueuedTask
//within a queued Task
//get the first line element in the layer
var ge = graphicsLayer.FindElement("Line 10") as GraphicElement;
var graphic = ge.GetGraphic();
if (graphic is CIMLineGraphic lineGraphic)
//change its symbol
lineGraphic.Symbol =
SymbolFactory.Instance.ConstructStroke(
ColorFactory.Instance.BlueRGB, 2, SimpleLineStyle.DashDot)).MakeSymbolReference();
//apply the change
ge.SetGraphic(lineGraphic);
