ArcGIS.Desktop.Layouts Namespace / MapSeries Class / CreateBookmarkMapSeries Method
The Layout you will ultimately apply the map series.
The MapFrame that contains the index layer.
    Creates a bookmark map series. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Shared Function CreateBookmarkMapSeries( _
       ByVal layout As Layout, _
       ByVal mapFrame As MapFrame _
    ) As BookmarkMapSeries
    public static BookmarkMapSeries CreateBookmarkMapSeries(
       Layout layout,
       MapFrame mapFrame
    Parameters
    layout
    mapFrame
    Return Value
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run.
    Remarks
    This method allows you to create a new bookmark map series using a minimum number of required paramters. It returns a CIMBookmarkMapSeries object that can be further modified using fine grained properties. To apply the changes to the layout, use the SetMapSeries() method.
    Requirements
