ArcGIS.Desktop.Mapping Namespace / GraphicsLayerExtensions Class / GroupElements Method
The elements to be grouped.
Example
    GroupElements Method (GraphicsLayerExtensions)
    Group the collection of elements. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Shared Function GroupElements( _
       ByVal graphicsLayer As GraphicsLayer, _
       ByVal elements As IEnumerable(Of Element) _
    ) As GroupElement
    Parameters
    graphicsLayer
    elements
    Return Value
    ArcGIS.Desktop.Layouts.GroupElement containing the grouped elements
    Exceptions
    ExceptionDescription
    elements cannot be null or empty
    elements must belong to graphicsLayer
    elements must be group elements or graphic elements
    element parents must be the same and non-null
    Map has reached maximum graphics count limit of 4000 elements. One or more elements cannot be created.
    Map has reached maximum graphics size limit of 10 MB. One or more elements cannot be created.
    Remarks
    All group elements in the input collection must have the same parent.
    Example
    Group Graphic Elements
      await QueuedTask.Run(() =>
        var elemsToGroup = graphicsLayer.GetSelectedElements();
        //group  elements
        groupElement = graphicsLayer.GroupElements(elemsToGroup);
    Requirements
