ArcGIS.Desktop.Mapping Namespace / GraphicsLayerExtensions Class / SendToBack Method / SendToBack(GraphicsLayer,Element) Method
The element to send to the back
    Send the element to the back of its parent's element collection. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public static void SendToBack(
       GraphicsLayer graphicsLayer,
       Element element
    Public Overloads Shared Sub SendToBack( _
       ByVal graphicsLayer As GraphicsLayer, _
       ByVal element As Element _
    Parameters
    graphicsLayer
    element
    Exceptions
    ExceptionDescription
    Value cannot be null: element
    elements must belong to graphicsLayer
    Remarks
    Refer to CanSendBackward(GraphicsLayer,Element) to check whether an element can be sent back. Element z order can only be changed relative to its parent's element collection. The bottom element will have a z order of 0 within the element parent's element collection. Check z order with ArcGIS.Desktop.Layouts.Element.ZOrder.
    The map view displaying the graphics layer should be initialized.
    Requirements
