ArcGIS.Core.CIM Namespace / CIMMaplexDictionaryEntry Class / Abbreviation Property
Example
    Abbreviation Property (CIMMaplexDictionaryEntry)
    Gets or sets the abbreviation.
    Syntax
    public string Abbreviation {get; set;}
    Public Property Abbreviation As String
    Example
    Create Abbreviation Dictionary in the Map Definition to a layer
      await QueuedTask.Run(() =>
      //Get the map's definition
      var mapDefn = map.GetDefinition();
      //Get the Map's Maplex labelling engine properties
      var mapDefnPlacementProps = mapDefn.GeneralPlacementProperties as CIMMaplexGeneralPlacementProperties;
      //Define the abbreviations we need in an array
      List<CIMMaplexDictionaryEntry> abbreviationDictionary = new List<CIMMaplexDictionaryEntry>
              new CIMMaplexDictionaryEntry {
              Abbreviation = "Hts",
              Text = "Heights",
              MaplexAbbreviationType = MaplexAbbreviationType.Ending
                  Abbreviation = "Ct",
                  Text = "Text",
              //etc
      //The Maplex Dictionary - can hold multiple Abbreviation collections
      var maplexDictionary = new List<CIMMaplexDictionary>
              new CIMMaplexDictionary {
                  Name = "NameEndingsAbbreviations",
                  MaplexDictionary = abbreviationDictionary.ToArray()
      //Set the Maplex Label Engine Dictionary property to the Maplex Dictionary collection created above.
      mapDefnPlacementProps.Dictionaries = maplexDictionary.ToArray();
      //Set the Map definition
      map.SetDefinition(mapDefn);
    Requirements
