| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
var mapWithClip = MapView.Active.Map;
await QueuedTask.Run(() =>
//If clipping is set to ArcGIS.Core.CIM.ClippingMode.None or ArcGIS.Core.CIM.ClippingMode.MapSeries null is returned
//If clipping is set to ArcGIS.Core.CIM.ClippingMode.MapExtent the ArcGIS.Core.CIM.CIMMap.CustomFullExtent is returned.
//Otherwise, if clipping is set to ArcGIS.Core.CIM.ClippingMode.CustomShape the custom clip polygon is returned.
var poly = mapWithClip.GetClipGeometry();
//You can use the polygon returned
//For example: We make a polygon graphic element and add it to a Graphics Layer.
var gl = mapWithClip.GetLayersAsFlattenedList().OfType<GraphicsLayer>().FirstOrDefault();
if (gl == null)
return;
var polygonSymbol = SymbolFactory.Instance.ConstructPolygonSymbol(CIMColor.CreateRGBColor(255, 255, 0));
var cimGraphicElement = new CIMPolygonGraphic
Polygon = poly,
Symbol = polygonSymbol.MakeSymbolReference()
gl.AddElement(cimGraphicElement);
