ArcGIS.Desktop.Mapping Namespace / Map Class / SetClipGeometry Method
    Overload List
    OverloadDescription
    Set map clipping to the provided clip polygon. This method must be called on the MCT. Use QueuedTask.Run.
    Set map clipping to the provided clip polygon. Specify layers or elevation surfaces to be excluded from the clipping operation. This method must be called on the MCT. Use QueuedTask.Run.
    Requirements
