ArcGIS.Desktop.Mapping Namespace / Map Class / SetClipGeometry Method / SetClipGeometry(Polygon,IEnumerable<Layer>,IEnumerable<ElevationSurfaceLayer>,CIMLineSymbol) Method
The clip polygon
A list of layers to exclude from the clipping. Pass null if no layers are to be excluded from the clipping operation.
A list of elevation surfaces to exclude from the clipping. Pass null if no elevation surfaces are to be excluded from the clipping operation.
The border symbol to use or null
    Set map clipping to the provided clip polygon. Specify layers or elevation surfaces to be excluded from the clipping operation. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    clipPolygon
    The clip polygon
    excludeLayers
    excludeSurfaces
    border
    Exceptions
    ExceptionDescription
    clipPolygon cannot be null
    "Excluded layers must be part of this map.";
    Remarks
    If the clip polygon is not in the spatial reference of the map it will be projected. Clipping will be set to ArcGIS.Core.CIM.ClippingMode.CustomShape. If the border symbol is null then the existing ArcGIS.Core.CIM.CIMMap.ClippingAreaBorderSymbol will be used. If ClippingAreaBorderSymbol is also null then a default line symbol will be assigned.
    Requirements
