ArcGIS.Desktop.Mapping Namespace / PieChartRendererDefinition Class / SizeOption Property
Example
    SizeOption Property (PieChartRendererDefinition)
    Gets and sets the pie chart size option
    Syntax
    public PieChartSizeOptions SizeOption {get; set;}
    Public Property SizeOption As PieChartSizeOptions
    Remarks
    Determines how the size of the overall pie chart symbol is set. Size can be either fixed: PieChartSizeOptions.Fixed, default, (all the same size) or proportional. If it is proportional, it is based either on the value of a particular field: PieChartSizeOptions.Field or the sum of all (eligible) fields: PieChartSizeOptions.SumSelectedFields
    For a value of PieChartSizeOptions.Field, specifiy the name of the field to use in FieldName otherwise the first eligible field will be used.
    Example
    Pie chart renderer for a feature layer
    /// <summary>
    /// Renders a feature layer using Pie chart symbols to represent data
    /// ![Pie chart renderer](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/pie-chart.png)
    /// </summary>
      //Check feature layer name
      //Code works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data
      var featureLayer = activeMap.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(f => f.Name == "USDemographics");
      if (featureLayer == null)
        MessageBox.Show("This renderer works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data", "Data missing");
      await QueuedTask.Run(() =>
        //Fields to use for the pie chart slices
        var chartFields = new List<string>
              "WHITE10",
               "BLACK10",
               "AMERIND10",
               "ASIAN10",
               "HISPPOP10",
               "HAMERIND10",
               "HWHITE10",
               "HASIAN10",
               "HPACIFIC10",
               "HBLACK10",
                "HOTHRACE10"
        PieChartRendererDefinition pieChartRendererDefn = new PieChartRendererDefinition()
          ChartFields = chartFields,
          ColorRamp = colorRamp,
          SizeOption = PieChartSizeOptions.Field,
          FieldName = "BLACK10",
          FixedSize = 36.89,
          DisplayIn3D = true,
          ShowOutline = true,
          Orientation = PieChartOrientation.CounterClockwise,
        //Creates a "Renderer"
        var pieChartRenderer = featureLayer.CreateRenderer(pieChartRendererDefn);
        //Sets the renderer to the feature layer
        featureLayer.SetRenderer(pieChartRenderer);
    Requirements
