ArcGIS.Core.CIM Namespace / CIMKeyframeVoxelLayer Class
Properties Methods Events
    CIMKeyframeVoxelLayer Class Members
    The following tables list the members exposed by CIMKeyframeVoxelLayer.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the maximum data value.
    Public Property Gets or sets the minimum data value.
    Public Property Gets or sets the voxel surfaces.
    Public Property Gets or sets the path to the layer. (Inherited from ArcGIS.Core.CIM.CIMKeyframeLayer)
    Public Property Gets or sets the static cross section planes.
    Public Property Gets or sets the dynamic cross section planes.
    Public Property Gets or sets a value indicating whether the surface is shown instead of the volume.
    Public Property Gets or sets the slice planes.
    Public Property Gets or sets the direction to clip from an edge. (Inherited from ArcGIS.Core.CIM.CIMKeyframeLayer)
    Public Property Gets or sets the amount of the visible area to clip. (Inherited from ArcGIS.Core.CIM.CIMKeyframeLayer)
    Public Property Gets or sets the transparency of the keyframe as a percentage. (Inherited from ArcGIS.Core.CIM.CIMKeyframeLayer)
    Public Property Gets or sets the method of transition for the transparency of the layer. (Inherited from ArcGIS.Core.CIM.CIMKeyframeLayer)
    Public Property Gets or sets the name of the current symbolizer variable.
    Public Property Gets or sets the vertical exaggeration. (Inherited from ArcGIS.Core.CIM.CIMKeyframeLayer)
    Public Property Gets or sets a value indicating whether the layer is visible. (Inherited from ArcGIS.Core.CIM.CIMKeyframeLayer)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMKeyframeVoxelLayer.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMKeyframeVoxelLayer with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMKeyframeVoxelLayer and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
