static void ValidateTopology()
using (Geodatabase geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(@"C:\TestData\GrandTeton.gdb"))))
using (ArcGIS.Core.Data.Topology.Topology topology = geodatabase.OpenDataset<ArcGIS.Core.Data.Topology.Topology>("Backcountry_Topology"))
// If the topology currently does not have dirty areas, calling Validate() returns an empty envelope.
ValidationResult result = topology.Validate(new ValidationDescription(topology.GetExtent()));
Console.WriteLine($"'AffectedArea' after validating a topology that has not been edited => {result.AffectedArea.ToJson()}");
// Now create a feature that purposely violates the "PointProperlyInsideArea" topology rule. This action will
// create dirty areas.
Feature newFeature = null;
try
// Fetch the feature in the Campsites feature class whose objectID is 2. Then create a new geometry slightly
// altered from this and use it to create a new feature.
using (Feature featureViaCampsites2 = GetFeature(geodatabase, "Campsites", 2))
Geometry currentGeometry = featureViaCampsites2.GetShape();
Geometry newGeometry = GeometryEngine.Instance.Move(currentGeometry, (currentGeometry.Extent.XMax / 8), (currentGeometry.Extent.YMax / 8));
using (FeatureClass campsitesFeatureClass = featureViaCampsites2.GetTable())
using (FeatureClassDefinition definition = campsitesFeatureClass.GetDefinition())
using (RowBuffer rowBuffer = campsitesFeatureClass.CreateRowBuffer())
rowBuffer[definition.GetShapeField()] = newGeometry;
geodatabase.ApplyEdits(() => { newFeature = campsitesFeatureClass.CreateRow(rowBuffer); });
// After creating a new feature in the 'Campsites' participating feature class, the topology's state should be
// "Unanalyzed" because it has not been validated.
Console.WriteLine($"The topology state after an edit has been applied => {topology.GetState()}");
// Now validate the topology. The result envelope corresponds to the dirty areas.
Console.WriteLine($"'AffectedArea' after validating a topology that has just been edited => {result.AffectedArea.ToJson()}");
// After Validate(), the topology's state should be "AnalyzedWithErrors" because the topology currently has errors.
Console.WriteLine($"The topology state after validate topology => {topology.GetState()}");
// If there are no dirty areas, the result envelope should be empty.
Console.WriteLine($"'AffectedArea' after validating a topology that has just been validated => {result.AffectedArea.ToJson()}");
finally
if (newFeature != null)
geodatabase.ApplyEdits(() => { newFeature.Delete(); });
newFeature.Dispose();
// Validate again after deleting the newly-created feature.
