Public Function GetFeatureClassNames() As IReadOnlyList(Of String)
public IReadOnlyList<string> GetFeatureClassNames()
Return Value
The name of all the ArcGIS.Core.Data.FeatureClasss that participate in the Topology.
| Exception | Description |
| ArcGIS.Core.Data.Exceptions.GeodatabaseException | A geodatabase-related exception has occurred. |
static void OpenTopologyAndProcessDefinition()
// Open a geodatabase topology from a file geodatabase and process the topology definition.
using (Geodatabase geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(@"C:\TestData\GrandTeton.gdb"))))
using (ArcGIS.Core.Data.Topology.Topology topology = geodatabase.OpenDataset<ArcGIS.Core.Data.Topology.Topology>("Backcountry_Topology"))
ProcessDefinition(geodatabase, topology);
// Open a feature service topology and process the topology definition.
const string TOPOLOGY_LAYER_ID = "0";
using (Geodatabase geodatabase = new Geodatabase(new ServiceConnectionProperties(new Uri("https://sdkexamples.esri.com/server/rest/services/GrandTeton/FeatureServer"))))
using (ArcGIS.Core.Data.Topology.Topology topology = geodatabase.OpenDataset<ArcGIS.Core.Data.Topology.Topology>(TOPOLOGY_LAYER_ID))
static void ProcessDefinition(Geodatabase geodatabase, ArcGIS.Core.Data.Topology.Topology topology)
// Similar to the rest of the Definition objects in the Core.Data API, there are two ways to open a dataset's
// definition -- via the Topology dataset itself or via the Geodatabase.
using (TopologyDefinition definitionViaTopology = topology.GetDefinition())
OutputDefinition(geodatabase, definitionViaTopology);
using (TopologyDefinition definitionViaGeodatabase = geodatabase.GetDefinition<TopologyDefinition>("Backcountry_Topology"))
OutputDefinition(geodatabase, definitionViaGeodatabase);
static void OutputDefinition(Geodatabase geodatabase, TopologyDefinition topologyDefinition)
Console.WriteLine($"Topology cluster tolerance => {topologyDefinition.GetClusterTolerance()}");
Console.WriteLine($"Topology Z cluster tolerance => {topologyDefinition.GetZClusterTolerance()}");
IReadOnlyList<string> featureClassNames = topologyDefinition.GetFeatureClassNames();
Console.WriteLine($"There are {featureClassNames.Count} feature classes that are participating in the topology:");
foreach (string name in featureClassNames)
// Open each feature class that participates in the topology.
using (FeatureClass featureClass = geodatabase.OpenDataset<FeatureClass>(name))
using (FeatureClassDefinition featureClassDefinition = featureClass.GetDefinition())
Console.WriteLine($"\t{featureClass.GetName()} ({featureClassDefinition.GetShapeType()})");
