ArcGIS.Core.Data.Topology Namespace / TopologyDefinition Class / GetRules Method
Example
    GetRules Method (TopologyDefinition)
    Gets the TopologyRules defined for this Topology. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Return Value
    The TopologyRules defined for this Topology.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Example
    Get topology rules
      static void GetTopologyRules()
        using (Geodatabase geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(@"C:\TestData\GrandTeton.gdb"))))
        using (ArcGIS.Core.Data.Topology.Topology topology = geodatabase.OpenDataset<ArcGIS.Core.Data.Topology.Topology>("Backcountry_Topology"))
          using (TopologyDefinition topologyDefinition = topology.GetDefinition())
            IReadOnlyList<TopologyRule> rules = topologyDefinition.GetRules();
            Console.WriteLine($"There are {rules.Count} topology rules defined for the topology:");
            Console.WriteLine("ID \t Origin Class \t Origin Subtype \t Destination Class \t Destination Subtype \t Rule Type");
            foreach (TopologyRule rule in rules)
              Console.Write($"{rule.ID}");
              Console.Write(!String.IsNullOrEmpty(rule.OriginClass) ? $"\t{rule.OriginClass}" : "\t\"\"");
              Console.Write(rule.OriginSubtype != null ? $"\t{rule.OriginSubtype.GetName()}" : "\t\"\"");
              Console.Write(!String.IsNullOrEmpty(rule.DestinationClass) ? $"\t{rule.DestinationClass}" : "\t\"\"");
              Console.Write(rule.DestinationSubtype != null ? $"\t{rule.DestinationSubtype.GetName()}" : "\t\"\"");
              Console.Write($"\t{rule.RuleType}");
              Console.WriteLine();
    Mark and unmark errors or exceptions
      static void MarkAndUnmarkAsErrors(ArcGIS.Core.Data.Topology.Topology topology)
        // Get all the errors due to features violating the "PointProperlyInsideArea" topology rule.
          TopologyRule pointProperlyInsideAreaRule = topologyDefinition.GetRules().First(rule => rule.RuleType == TopologyRuleType.PointProperlyInsideArea);
          ErrorDescription errorDescription = new ErrorDescription(topology.GetExtent())
            TopologyRule = pointProperlyInsideAreaRule
          IReadOnlyList<TopologyError> errorsDueToViolatingPointProperlyInsideAreaRule = topology.GetErrors(errorDescription);
          Console.WriteLine($"There are {errorsDueToViolatingPointProperlyInsideAreaRule.Count} feature violating the 'PointProperlyInsideArea' topology rule.");
          // Mark all errors from features violating the 'PointProperlyInsideArea' topology rule as exceptions.
          foreach (TopologyError error in errorsDueToViolatingPointProperlyInsideAreaRule)
            topology.MarkAsException(error);
          // Now verify all the errors from features violating the 'PointProperlyInsideArea' topology rule have indeed been
          // marked as exceptions.
          // By default, ErrorDescription is initialized to ErrorType.ErrorAndException.  Here we want ErrorType.ErrorOnly.
            ErrorType = ErrorType.ErrorOnly,
          IReadOnlyList<TopologyError> errorsAfterMarkedAsExceptions = topology.GetErrors(errorDescription);
          Console.WriteLine($"There are {errorsAfterMarkedAsExceptions.Count} feature violating the 'PointProperlyInsideArea' topology rule after all the errors have been marked as exceptions.");
          // Finally, reset all the exceptions as errors by unmarking them as exceptions.
            topology.UnmarkAsException(error);
          IReadOnlyList<TopologyError> errorsAfterUnmarkedAsExceptions = topology.GetErrors(errorDescription);
          Console.WriteLine($"There are {errorsAfterUnmarkedAsExceptions.Count} feature violating the 'PointProperlyInsideArea' topology rule after all the exceptions have been reset as errors.");
    Requirements
