Parameters
- obj
- The object to compare with the current object.
Return Value
true if the specified object is equal to the current object; otherwise, false.true if the specified object is equal to the current object; otherwise, false.TopologyNode instances refer to the same backing nativeTopologyNode instance in native code, they are considered equal.Target Platforms: Windows 11 Home, Pro, Enterprise (64 bit)
