Public Function GetExteriorRing( _ ByVal index As Integer, _ Optional ByVal setSpatialReference As Boolean _ ) As Polygon
public Polygon GetExteriorRing( int index, bool setSpatialReference )
Parameters
- index
- The index of the exterior ring. Note that this is not the index of the part in the polygon. Use ExteriorRingCount to determine the number of exterior rings in this polygon.
- setSpatialReference
- (Optional) Determines if the spatial reference should be set in each of the returned polygons. If setSpatialReference is set to true, then the spatial reference in each polygon is inherited from this polygon. If setSpatialReference is set to false, then the spatial reference in each polygon is set to null. The default value is true.
Return Value
A polygon representing the exterior ring.
