ArcGIS.Desktop.Mapping Namespace / Map Class / GetElevationProfileFromSurface Method / GetElevationProfileFromSurface(MapPoint,MapPoint,Int32) Method
The start point.
The end point.
The number of points required in the resulting polyline. Note this count includes the start and end points. There must be at least 10 points.
Example
    Gets an elevation profile calculated between startPoint and endPoint. Intermediate points are calculated at equal distances between the end points according to the numPoints specified. The Z values of the calculated polyline are populated from the Ground Surface Layer. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function GetElevationProfileFromSurface( _
       ByVal startPoint As MapPoint, _
       ByVal endPoint As MapPoint, _
       ByVal numPoints As Integer _
    ) As ElevationProfileResult
    public ElevationProfileResult GetElevationProfileFromSurface(
       MapPoint startPoint,
       MapPoint endPoint,
       int numPoints
    Parameters
    startPoint
    The start point.
    endPoint
    The end point.
    numPoints
    Return Value
    An ElevationProfileResult. If successful, this contains the generated polyline.
    Exceptions
    ExceptionDescription
    startPoint or endPoint are null.
    startPoint or endPoint cannot be empty.
    numPoints cannot be smaller than 10.
    This Map does not have a visible Ground Surface Layer.
    Example
    Interpolate a line between two points and calculate the elevation profile
        int numPoints = 20;//Or any number of points you want to interpolate
                           // use a specific elevation surface
        var eleLayer = MapView.Active.Map.GetElevationSurfaceLayers().FirstOrDefault(l => l.Name == "TIN");
        // use the default ground elevation surface
        MapPoint startPt = MapPointBuilderEx.CreateMapPoint(-130, 20, SpatialReferences.WGS84);
        MapPoint endPt = MapPointBuilderEx.CreateMapPoint(-100, 50, SpatialReferences.WGS84);
        var result = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(startPt, endPt, numPoints);
        if (result.Status == SurfaceZsResultStatus.Ok)
            var polylineZ = result.Polyline;
            // process the polylineZ
        result = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(startPt, endPt, numPoints, eleLayer);
    Show Elevation profile graph using an ElevationProfileResult
        var elevProfileResult = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(startPt, endPt, 10);
        if (elevProfileResult.Status != SurfaceZsResultStatus.Ok)
            return;
        if (!MapView.Active.CanShowElevationProfileGraph())
            return;
        // show the elevation profile using the result
        MapView.Active.ShowElevationProfileGraph(elevProfileResult);
    Requirements
    ArcGIS Pro version: 3.4 or higher.
