ArcGIS.Desktop.Mapping Namespace / Map Class / GetElevationProfileFromSurface Method
    Overload List
    OverloadDescription
    Gets an elevation profile for the specified polylines. The Z values of the calculated polyline are populated from the Ground Surface Layer. This method must be called on the MCT. Use QueuedTask.Run.
    Gets an elevation profile for the specified polylines. The Z values of the calculated polyline are populated from the specified Elevation Surface Layer. This method must be called on the MCT. Use QueuedTask.Run.
    Gets an elevation profile for the specified points. The Z values of the calculated polyline are populated from the Ground Surface Layer. This method must be called on the MCT. Use QueuedTask.Run.
    Gets an elevation profile for the specified points. The Z values of the calculated polyline are populated from the specified Elevation Surface Layer. This method must be called on the MCT. Use QueuedTask.Run.
    Gets an elevation profile calculated between startPoint and endPoint. Intermediate points are calculated at equal distances between the end points according to the numPoints specified. The Z values of the calculated polyline are populated from the Ground Surface Layer. This method must be called on the MCT. Use QueuedTask.Run.
    Gets an elevation profile calculated between startPoint and endPoint. Intermediate points are calculated at equal distances between the end points according to the numPoints specified. The Z values of the calculated polyline are populated from the specified Elevation Surface Layer. This method must be called on the MCT. Use QueuedTask.Run.
    Requirements
    ArcGIS Pro version: 3.4 or higher.
